KIMSEN 株式会社は JIS H4100および EN 755-9 のような国際規格を満たす高品質の押出アルミニウム及び コンポーネントを製造して提供しております。当社は押出、陽極酸化、静電粉体塗装、精密機械加工が4つのワークショップございます。2016年にISO9001及びISO 14001を取りました。
* KIMSEN Solar System is made of anodized aluminum, which brings a high aesthetic to the product; Durable and lightweight materials make it easy to install and transport, maximizing cost savings for customers.
* KIMSEN provides precision machining services with the most advanced technology: CNC milling, cutting, drilling, punching, laser engraving, bending, etc.
* We provide surface treatment solutions applied with the most advanced technology:
- Anodizing
- Powder Coating
- NCP (Non Chrome Pretreament)
- Wood grain coloring
- Sand blasting
* We manufacture pre-assembled modules made from aluminum, steel and other materials for multiple industries such as telecommunications, mechanics, electronics, etc.
- Telecommunication application: Antenna modules
- Mechanical & Electrical application: Electrical application, communication equipment, mechanical application
* Custom OEM services. Wood or carton packages as customer request.
- Anodizing
- Powder Coating
- Sand blasting
* Given its excellent heat transfer properties and conductivity, aluminum components are used in numerous electrical and electronic appliances such as motor housings, high-dissipation heat sinks, etc.
* Application of KIMSEN's heat sinks: Heat sinks for PC computers, LED heat sinks, etc.
- Anodizing
- Powder Coating
- Sand blasting
* KIMSEN's electrical components are diverse in types, including: Tracking lighting section, amplifier faceplate, etc.
- Anodizing
- Powder Coating
- Sand blasting
* KIMSEN's electronic components are diverse in types, including: BGA, FPGA heat sinks, LED heat sinks, Fan heat sinks, hard drives heat sinks, amplifier heat sinks, etc.
- Anodizing
- Powder Coating
- Sand blasting
* KIMSEN's ancillary components are diverse in types, including: Jig, fixture, vacuum jig, etc.
- Anodizing
- Powder Coating
- Sand blasting
* KIMSEN's mechanical components are diverse in types, including: Motor housing, machine parts, etc.
- Anodizing
- Powder Coating
- Sand blasting
With its pliability, lightweight and strength, aluminum extrusion offers endless application opportunities in Architecture & Construction, Energy, Transportation & Vehicles, Electronics, Industrial Design and General Engineering.
KIMSEN provides surface treatment solutions applied with the most advanced technology:
- Anodizing
- Powder Coating
- Sand blasting
アルミ合金( 量産 / 機械加工 ) |
KIMSEN工業株式会社 (キムセンコウギョウカブシキガイシャ) |
自社ホームページURL | http://kimsen.vn/ |
ベトナム バクニン イェンフォン県、イェンフォン工業団地
担当者 | |
電話番号 | +84-+84-243-795-7410 | FAX番号 | +84-+84-243-795-7412 |
資本金 | 社員数 | 260人 | |
年間売上高 | エミダス会員番号 | 92382 | |
産業分類 | 治工具 / 電子部品 | ||
試作開発・少量生産 | 機械加工 | 自動溶断加工 アルミ合金 ブローチ盤加工 |
試作開発・少量生産 | NC機械加工 | NCフライス加工 NC旋盤加工 |
試作開発・少量生産 | カッティング・ブランク | 微細加工(レーザー) 精密切断加工 |
量産 | 機械加工 | マシニング加工 NCフライス加工 微細穴加工 アルミ合金 |
表面処理 | メッキ・化成処理 | アルマイト(陽極酸化) アルミ |
表面処理 | 塗装 | 粉体塗装 静電塗装 |
表面処理 | 印刷等 | NC彫刻加工 |
表面処理 | その他表面処理 | サンドブラスト イオンプレーティング |
自動車部品製造 | ボディーパーツ | その他、ボディパーツ |
自動車部品製造 | エンジン | ラジエター部品 |
