Micro-Bubble Jet type Salinity removal Equipment "Hyper Washer"
This product is a dedicated salt cleaning device that cleans salt adhering to aircraft, vehicles, ships, steel bridges and other steel structures with low-pressure jet water flow containing micro-bubbles, and prevents salt damage corrosion. It has the following features.
1) Long-distance injection
The micro-bubble mist jet with an effective injection length of 10 m or more enables safe and efficient cleaning work in high places and long-distance areas.
the object to be cleaned.
2) Low pressure cleaning
Since the injection pressure is the same as the pneumatic pressure (standard pressure: 0.6 to 0.7Mpa) of the drive source of this device, the object to be cleaned will not be damaged.
